Ana içeriğe geç
Lenovo ThinkPad T431S Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T431S Fan Replacement, Fan: adım 1, 2 resimden 1. Lenovo ThinkPad T431S Fan Replacement, Fan: adım 1, 2 resimden 2.
    • Remember before starting any disassembly, to prevent electric shock or harm, disconnect from any external power source and make sure device is powered off.
    • Use a Phillips #1 screwdriver bit to remove eight 5.0 mm screws from the back panel.
    • Carefully pry off the back panel using the opening tool.
  2. Lenovo ThinkPad T431S Fan Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T431S Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver bit and remove the four 3.0 mm screws from the heatsink.
  3. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T431S Fan Replacement: adım 3, 3 resimden 3.
    • Disconnect the cable attached to the fan, pulling the connector straight down.
    • Lift and remove the fan.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Well done. I will have a go at fixing the fan on my T430s now that I’ve seen how easy it is to do.
Jocko - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 393
