Giriş
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
9 farklı kişi bu kılavuzu tamamladı.
