Giriş
This guide requires some caution when removing the cables connected to the wireless adapter. Use a spudger and avoid using tweezers with metallic points as it could damage the cable. The remainder of the guide is simple and requires unscrewing a screw.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
Use the spudger to remove the two cables that are connected to the wireless adapter.
Bir başkası bu kılavuzu tamamladı.
