Giriş
Use this guide to replace the camera/microphone module cable in a Lenovo ThinkPad T460.
The built-in webcam (also called a laptop camera) in this laptop is integrated with the webcam. If you are experiencing issues with the webcam and microphone and have ruled out the camera/microphone module itself as the issue, you may need to replace your laptop’s camera/microphone module cable.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Neye ihtiyacın var
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Remove the two 3.7 mm screws from the LCD cable bracket using a Phillips #1 screwdriver.
Use your hands to peel up the thin LCD bezel sheet from the rest of the display, starting in the area between the hinges.
Use your hands to continue peeling the bezel sheet away from the left side of the laptop.
Use both hands to lift the bottom corners of the display panel
Gently flip the display panel over.
Use your fingers to peel the large copper tape up from the display assembly in the bottom left-hand corner.
