Ana içeriğe geç
Lenovo ThinkPad T460s RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T460s RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s RAM Replacement: adım 2, 1 resimden 1.
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s RAM Replacement: adım 3, 1 resimden 1.
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s RAM Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad T460s RAM Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad T460s RAM Replacement: adım 4, 3 resimden 3.
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
  5. Lenovo ThinkPad T460s RAM Replacement, RAM: adım 5, 3 resimden 1. Lenovo ThinkPad T460s RAM Replacement, RAM: adım 5, 3 resimden 2. Lenovo ThinkPad T460s RAM Replacement, RAM: adım 5, 3 resimden 3.
    • To remove the existing RAM module, pull tabs marked in the red outwards.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 25
Son 30 gün: 105
Her zaman: 5,471
