Ana içeriğe geç
Lenovo ThinkPad T470S Batteries Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T470S Batteries Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: adım 2, 3 resimden 1. Lenovo ThinkPad T470S Batteries Replacement, Batteries: adım 2, 3 resimden 2. Lenovo ThinkPad T470S Batteries Replacement, Batteries: adım 2, 3 resimden 3.
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470S Batteries Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad T470S Batteries Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad T470S Batteries Replacement: adım 3, 3 resimden 3.
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Is the rear battery, battery 1 or 2? It's my battery 2 that won't charge any more. But maybe I should just change them both. Do you sell both of them or just the one?
Trisha Moore - Yanıt
I am facing the same issue. What have u done for this... Which battery u changed the external one or internal?
Ayesha Sajid -
Battery 1 (00HW023) is the larger of the two and sits under the track pad. Battery 2 (01AV406) is the smaller one and sits by the hinge to the screen.
Jesus Diaz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 245
Son 30 gün: 1,129
Her zaman: 38,994
