Ana içeriğe geç
Lenovo ThinkPad T480 SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480 SSD Replacement, SSD: adım 1, 1 resimden 1.
  2. Lenovo ThinkPad T480 SSD Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 2, 2 resimden 2.
    • Push Clip 1 to the side. While holding Clip 2 to the side, push the battery out of the laptop.
  3. Lenovo ThinkPad T480 SSD Replacement: adım 3, 1 resimden 1.
    • Remove all Phillip-head screws shown.
    • The screws will not come out of the casing, so unscrew them all the way until they don’t go any higher.
  4. Lenovo ThinkPad T480 SSD Replacement: adım 4, 1 resimden 1.
    • Pry up on the casing using a spudger or a flat-head screwdriver and remove the back.
  5. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 5, 3 resimden 3.
    • Pry up on the little metal bar on the connector and pull the connector out of its socket.
  6. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 6, 3 resimden 3.
    • Pry up on the left side of the SSD casing. Pull the casing to the left, and remove.
  7. Lenovo ThinkPad T480 SSD Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 7, 2 resimden 2.
    • Remove the following 4mm Phillip-head screws and remove the plate.
  8. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480 SSD Replacement: adım 8, 3 resimden 3.
    • Remove the 4mm Phillip-head screw and pull the SSD out of its socket.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Dane Elliott-Dyson
618 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 120
Son 30 gün: 529
Her zaman: 5,979
