Ana içeriğe geç
Lenovo ThinkPad T480s LCD Panel Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 2, 3 resimden 3.
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s LCD Panel Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 3, 2 resimden 2.
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: adım 4, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: adım 4, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Assembly: adım 4, 3 resimden 3.
    • Use the spudger to disconnect the coaxial cables from the Wi-Fi card and WWAN card.
    • When reassembling the Wi-Fi card, reattach the black wire closest to the screw and the gray wire on the other side of the black wire. With the WWAN card, reattach the blue wire on the left and the orange wire on the right.
    • There are also small color coded arrows on each card that match the corresponding wires, to make sure you connect to the correct spot.
  5. Lenovo ThinkPad T480s LCD Panel Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 5, 3 resimden 3.
    • Use the spudger to disconnect the LCD cable from the motherboard.
  6. Lenovo ThinkPad T480s LCD Panel Replacement: adım 6, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 6, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 6, 3 resimden 3.
    • Disconnect the camera cable from the motherboard using a spudger.
  7. Lenovo ThinkPad T480s LCD Panel Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 7, 2 resimden 2.
    • Remove all antenna cables from their routing.
  8. Lenovo ThinkPad T480s LCD Panel Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 8, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove three 5 mm screws from the left hinge and three 5 mm screws from the right hinge.
  9. Lenovo ThinkPad T480s LCD Panel Replacement: adım 9, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 9, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 9, 3 resimden 3.
    • Carefully rotate the hinges upward and remove the bottom of the machine from the LCD unit.
  10. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: adım 10, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: adım 10, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Bezel: adım 10, 3 resimden 3.
    • Using the spudger, pry the LCD bezel up from the edges starting near the hinges.
    • It is attached by adhesive so be careful not to break it. You may hear loud snaps when detaching the clips; this is normal.
  11. Lenovo ThinkPad T480s LCD Panel Replacement: adım 11, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 11, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 11, 3 resimden 3.
    • Use the spudger to remove the internal bezel.
    • Start at the corner by the hinge and lift the edge of the internal bezel up with the pointed end of the spudger.
    • Hold the internal bezel with your fingers and work your way around the perimeter of the screen carefully pulling the bezel up.
    • You will feel resistance and hear snapping as you remove the bezel because it is connected with clips. Be careful that you don't crack the bezel. The plastic is delicate in places.
  12. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: adım 12, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement, LCD Panel: adım 12, 2 resimden 2.
    • Remove four 2.9 mm screws from the LCD panel using the Phillips #1 screwdriver.
  13. Lenovo ThinkPad T480s LCD Panel Replacement: adım 13, 3 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 13, 3 resimden 2. Lenovo ThinkPad T480s LCD Panel Replacement: adım 13, 3 resimden 3.
    • Gently lift the panel and flip it over.
    • The panel is still connected to the unit by the LCD cable so be careful not to rip the connector when flipping it over.
  14. Lenovo ThinkPad T480s LCD Panel Replacement: adım 14, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 14, 2 resimden 2.
    • Peel back the tape covering the LCD cable connector.
    • Use the spudger to unlock the LCD cable.
  15. Lenovo ThinkPad T480s LCD Panel Replacement: adım 15, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 15, 2 resimden 2.
    • Remove the LCD cable from the socket.
  16. Lenovo ThinkPad T480s LCD Panel Replacement: adım 16, 2 resimden 1. Lenovo ThinkPad T480s LCD Panel Replacement: adım 16, 2 resimden 2.
    • Remove the LCD panel from the system.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Sarah Westberg
29.704 İtibar
71 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.658 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hello, just wondering about step 4.
The description does not match what the image is showing for the Wi-Fi card wiring. The image is showing the black wire being closest to the screw (bottom) and the grey wire being on the opposite side (top). The description describes the opposite which is correct. The correct wiring can be seen in step 3 when the lid has been opened.
Kromagnon - Yanıt
Hi Kromagnon, thanks for pointing this out! I believe when I opened up the device, (which was likely used ), the Wi-Fi card cables were inadvertently switched (as shown in Step 3). I wrote my instructions based on how they were initially connected, but when reassembling I put the cables back correctly and missed the fact that the instructions were inconsistent. Step 4 is now correct. Thanks again!
Sarah Westberg -
Why even remove the Wifi cables? Do they actually get in the way of the replacement? I have done this before and don't think that they do.
Nathan Morris - Yanıt
Hi Nathan, thanks for your question. It looks like the Wi-Fi cables are connected to the display assembly, so they will need to be disconnected from the Wi-Fi card prior to removing the display.
Sarah Westberg -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 121
Her zaman: 7,209
