Ana içeriğe geç
Lenovo ThinkPad T490s Battery Cable Disconnect
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Lenovo ThinkPad T490s Battery Cable Disconnect, Loosen the back screws: adım 1, 2 resimden 1. Lenovo ThinkPad T490s Battery Cable Disconnect, Loosen the back screws: adım 1, 2 resimden 2.
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Cable Disconnect, Release the clips: adım 2, 2 resimden 1. Lenovo ThinkPad T490s Battery Cable Disconnect, Release the clips: adım 2, 2 resimden 2.
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Cable Disconnect: adım 3, 2 resimden 1. Lenovo ThinkPad T490s Battery Cable Disconnect: adım 3, 2 resimden 2.
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: adım 4, 3 resimden 1. Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: adım 4, 3 resimden 2. Lenovo ThinkPad T490s Battery Cable Disconnect, Remove the back cover: adım 4, 3 resimden 3.
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Cable Disconnect, Disconnect the battery cable: adım 5, 2 resimden 1. Lenovo ThinkPad T490s Battery Cable Disconnect, Disconnect the battery cable: adım 5, 2 resimden 2.
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
Sonuç
Clay Eickemeyer
82.645 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.554 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 27
