Ana içeriğe geç
Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Baseplate: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: adım 3, 3 resimden 1. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: adım 3, 3 resimden 2. Lenovo ThinkPad T495 Solid State Drive (SSD) Replacement, Solid State Drive: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a Phillips #00 screwdriver to remove the 6 mm screw.
    • Use tweezers or an iFixit opening tool to lift the SSD up and away from the thermal pad it rests on.
    • Grip the SSD between your fingers and pull it horizontally to the right at a slight angle until it releases from the port.
    • The thermal pad is slightly sticky, and may stick to the bottom of the SSD as you remove it. If it does, be careful not to damage it, and make sure to reinstall the thermal pad before replacing the SSD.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christian Taylor
523 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G6
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 50
Son 30 gün: 170
Her zaman: 3,327
