Ana içeriğe geç
Lenovo ThinkPad T495 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T495 Speaker Replacement, Baseplate: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Speaker Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Speaker Replacement, Speaker: adım 3, 3 resimden 1. Lenovo ThinkPad T495 Speaker Replacement, Speaker: adım 3, 3 resimden 2. Lenovo ThinkPad T495 Speaker Replacement, Speaker: adım 3, 3 resimden 3.
    • Grip the speaker cable as close as possible to its motherboard plug, and pull directly backwards, parallel to the motherboard, until the plug releases.
  4. Lenovo ThinkPad T495 Speaker Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad T495 Speaker Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 1.6 mm screws.
    • Holding both sides, lift the speaker up and out.
Sonuç
Christian Taylor
607 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 41
Her zaman: 656
