Ana içeriğe geç
Lenovo ThinkPad T495 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Baseplate: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
  2. Lenovo ThinkPad T495 Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
  3. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 3 resimden 1. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 3 resimden 2. Lenovo ThinkPad T495 Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to lift the two coaxial cable connectors vertically, disconnecting them from the Wi-Fi card.
    • Use a Phillips #00 screwdriver to remove the 6 mm screw, causing the Wi-Fi card to pop up.
  4. Lenovo ThinkPad T495 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad T495 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Grip the Wi-Fi card between your fingers and pull it in the direction of the card, at a slight angle, until it releases from its port.
Sonuç
Christian Taylor
607 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 üyesi
UMASSD-PETERSEN-S22S1G6
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 74
Her zaman: 1,284
