Ana içeriğe geç
Lenovo ThinkPad T560 Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T560 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Back Panel Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
Sonuç
Jackson Reynolds
517 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 57
Her zaman: 1,091
