Ana içeriğe geç
Lenovo ThinkPad T560 Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: adım 3, 2 resimden 1. Lenovo ThinkPad T560 Fan Replacement, Battery: adım 3, 2 resimden 2.
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: adım 5, 3 resimden 1. Lenovo ThinkPad T560 Fan Replacement, Fan: adım 5, 3 resimden 2. Lenovo ThinkPad T560 Fan Replacement, Fan: adım 5, 3 resimden 3.
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: adım 6, 1 resimden 1.
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: adım 7, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
Sonuç
Jackson Reynolds
517 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 51
Her zaman: 1,037
