Ana içeriğe geç
Lenovo ThinkPad T560 SSD/Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 SSD/Hard Drive Replacement, SSD/Hard Drive: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the 3.5mm screw securing the SSD/Hard Drive.
  4. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pick up the SSD/Hard Drive and unplug it from the cable connecting the SSD/Hard Drive to the motherboard.
  5. Lenovo ThinkPad T560 SSD/Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove SSD/Hard Drive case from the drive.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jackson Reynolds
517 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-3, Hunter Spring 2022 Clemson, Team 1-3, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G3
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 39
Son 30 gün: 191
Her zaman: 5,925
