Ana içeriğe geç
Lenovo ThinkPad T560 Thermal Paste Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad T560 Thermal Paste Replacement, Opening the laptop: adım 1, 2 resimden 1. Lenovo ThinkPad T560 Thermal Paste Replacement, Opening the laptop: adım 1, 2 resimden 2.
    • Unscrew the 8 screws holding the back panel in place.
    • Remove the battery by sliding the notches and pulling the battery outwards.
    • Use a plastic prying tool to release all the clips holding the panel in place.
  2. Lenovo ThinkPad T560 Thermal Paste Replacement, The insides: adım 2, 1 resimden 1.
    • It is recommended to disconnect the second battery too.
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
  3. Lenovo ThinkPad T560 Thermal Paste Replacement, Changing the thermal paste: adım 3, 2 resimden 1. Lenovo ThinkPad T560 Thermal Paste Replacement, Changing the thermal paste: adım 3, 2 resimden 2.
    • Unscrew the 4 screws holding the CPU cooler. Disconnect the fan cable by releasing the latch on the connector and pulling the cable out.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton buds or paper towel, but be careful not to go too hard on the CPU.
    • Once you removed the old thermal paste its time to apply new one.
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure. Dont forget to plug in the fan cable.
Sonuç
Simeon Brankov
7.180 İtibar
54 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 49
Her zaman: 632
