Giriş
This guide will show you how to replace the SSD for the Lenovo ThinkPad T570. Make sure that the device is powered down and the battery is removed from the underside of the computer. There are delicate parts connected to the SSD, so be sure to use careful, deliberate movements so none of the parts underneath become damaged or displaced.
Neye ihtiyacın var
Switch the left latch to the left to unlock the battery.
While holding the right latch to the right, slide the battery away from the device.
Loosen the seven captive screws on the back panel of the computer using a Phillips #0 screwdriver.
Remove the back panel.
