Ana içeriğe geç
Lenovo ThinkPad W540 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad W540 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 2 resimden 1. Lenovo ThinkPad W540 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the captive screw that secures the Wi-Fi card compartment plate.
    • The screw that holds on to the WiFi card compartment plate should hold on to the plate itself. So you shouldn't worry about losing it
    • Note the position of the gray and black cables on the Wi-Fi card.
  2. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using your Tweezers start with either of the gray or black cables and carefully dislodge them
  3. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw that fastens the Wi-Fi card.
  4. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 4, 2 resimden 1. Lenovo ThinkPad W540 Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Using your hand or a capable device, carefully detach the Wi-Fi card.
Sonuç
Bryan O
109 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-2, Konn Fall 2023 UMass Dartmouth, Team 3-2, Konn Fall 2023 üyesi
UMASSD-KONN-F23S3G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 124
