Ana içeriğe geç
Lenovo ThinkPad W541 Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: adım 1, 2 resimden 1. Lenovo ThinkPad W541 Touchpad Replacement, Touchpad: adım 1, 2 resimden 2.
    • Slide the clips to the left and right sides, remove the battery upwards.
    • Loosen two Phillips #00 screws and open the cover plate.
    • Remove four 9.0 mm Phillips #00 case screws.
    • Remove three 9.0 mm Phillips #00 screws circled with red in the second picture.
  2. Lenovo ThinkPad W541 Touchpad Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad W541 Touchpad Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad W541 Touchpad Replacement: adım 2, 3 resimden 3.
    • Use the pry bar to push the keypad below the slot shown in the first picture and push it upward.
    • Loosen six Phillips #000 screws circled with red in the second picture, lift up the keyboard.
  3. Lenovo ThinkPad W541 Touchpad Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad W541 Touchpad Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad W541 Touchpad Replacement: adım 3, 3 resimden 3.
    • Open the black clips according to the direction marked in the first picture and remove the cable.
    • Use a pry bar to pry open the black protective casing upwards.
    • Follow the direction shown in the third picture, open the black clips upwards and remove the cable.
  4. Lenovo ThinkPad W541 Touchpad Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad W541 Touchpad Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad W541 Touchpad Replacement: adım 4, 3 resimden 3.
    • Remove the four 2.0 mm Phillips #000 screws circled with red in the first picture.
    • Carefully remove the metal tape shown in the second picture and paste it back on after replacing the new touchpad.
    • As shown in the third picture, remove the trackpad that needs to be replaced.
  5. Lenovo ThinkPad W541 Touchpad Replacement: adım 5, 1 resimden 1.
    • You can replace your touchpad with a new one. To install your computer just follow this guide in reverse.
Sonuç
Panaien Liu
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 370
