Ana içeriğe geç
Lenovo ThinkPad W550S BIOS Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad W550S BIOS Battery Replacement, Open the case: adım 1, 1 resimden 1.
    • Make sure the laptop is off and remove the battery.
    • Loosen all screws (these remain in the case bottom) with a PH 00 screwdriver.
    • Open the clips around the case with an iFixit opening tool.
  2. Lenovo ThinkPad W550S BIOS Battery Replacement, Opening the case: adım 2, 1 resimden 1.
    • To remove the case bottom, you have to lift it slightly and push it backwards.
    • Be careful not to damage the case!
  3. Lenovo ThinkPad W550S BIOS Battery Replacement, Remove battery: adım 3, 1 resimden 1.
    • Carefully remove the foil
    • Disconnect the plug of the battery.
    • Remove the battery from the circuit board. This is glued to the circuit board with a spacer.
  4. Lenovo ThinkPad W550S BIOS Battery Replacement, Replace battery: adım 4, 1 resimden 1.
    • Find a replacement battery based on the type designation (in my case a 08K8050 - CR 2032 3V) and insert it.
Sonuç
Work through the steps in reverse order to reassemble your device.
Bu çevirmenlere özel teşekkürler:
de en
100%
oldturkey03 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Michael
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,129
