Ana içeriğe geç
Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: adım 3, 2 resimden 1. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Battery: adım 3, 2 resimden 2.
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 4, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 5, 1 resimden 1.
    • Remove the battery by pulling it directly towards you.
  6. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement, Fan: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to undo the four 5 mm screws attached to the heat sink.
  7. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 7, 1 resimden 1.
    • Undo the black clasp that holds the ribbon cable, attached to the fan, in place and disconnect the ribbon cable.
  8. Lenovo ThinkPad X1 Carbon (2nd Gen) Fan Replacement: adım 8, 1 resimden 1.
    • Remove the fan by lifting it directly up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
Cal Poly, Team S18-G4, White Winter 2020 Cal Poly, Team S18-G4, White Winter 2020 üyesi
CPSU-WHITE-W20S18G4
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 36
Her zaman: 1,307
