Giriş
Follow this guide if you wish to replace the CMOS battery on your Lenovo ThinkPad X1 Carbon 5th Gen, Type 20K3-S0DQ00 S/N PF-0VPYSA 1710. This will be a fairly simple guide and should be quick for most users. Having a proper a CMOS battery allows for the laptop to be used without being connected to a power source.
The device should be powered off and disconnected from the charger when being worked on.
Neye ihtiyacın var
Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
Bir başkası bu kılavuzu tamamladı.
