Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 3, 1 resimden 1.
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: adım 4, 2 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Battery: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the four 1.2 mm screws that secure the battery.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 5, 3 resimden 3.
    • Remove the battery using your hand or a prying tool.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: adım 6, 2 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement, Speakers: adım 6, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the two 1.2 mm screws.
  7. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 7, 3 resimden 3.
    • Unplug the speaker cable from the board.
  8. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad X1 Carbon 5th Gen Speakers Replacement  Replacement: adım 8, 3 resimden 3.
    • Lift up the marked latch and remove the cable.
    • Remove the speaker.
Sonuç
You will have the speaker replaced and fully working. To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Diego Garcia reyes
493 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 804
