Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the laptop on to its back.
  2. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove five 1.2 mm screws from the back cover of the laptop.
  3. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: adım 3, 1 resimden 1.
    • Remove the back cover using the opening tool, leaving the laptop back exposed.
    • Use the opening tool to pry the edge and work your way around the perimeter.
    • Careful to undo the clips before removing the back cover.
  4. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    • Use the Phillips #1 screwdriver to remove the 1.2 mm screw that's holding the Wi-Fi card in place.
  5. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: adım 5, 1 resimden 1.
    • Disconnect the white and black coaxial antenna cables from the Wi-Fi card.
  6. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X1 Carbon 5th Gen Wi-Fi Card  Replacement: adım 6, 2 resimden 2.
    • Slide the card out to remove it from the laptop.
Sonuç
Diego Garcia reyes
493 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Saknee Fall 2021 Gateway, Team 1-3, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 922
