Neye ihtiyacın var
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use the Phillips #0 screwdriver to remove the four 5 mm screws that secure the battery to the laptop frame.
Use a Phillips #0 screwdriver to remove the single screw that secures the SSD to the motherboard.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
Detach the last ribbon cable in the same way as before.
For the red and orange cables, use a spudger to lift the black plastic bar.
Use a PH0 screwdriver to remove the two 2mm screws holding the USB port in place.
3 farklı kişi bu kılavuzu tamamladı.
