Giriş
In this guide, you will learn how to replace the motherboard in a Lenovo ThinkPad X1 Carbon 6th Gen. Be sure to power off your device and disconnect it from any power source before beginning.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
Use a Phillips #0 screwdriver to loosen the four screws that secure the fan to the motherboard.
Remove each of the 7 main ribbon cables that connect the motherboard to the rest of the laptop.
Detach the last ribbon cable in the same way as before.
For the red and orange cables, use a spudger to lift the black plastic bar.
2 farklı kişi bu kılavuzu tamamladı.
