Ana içeriğe geç
Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Back cover removal: adım 1, 2 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Back cover removal: adım 1, 2 resimden 2.
    • Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
  2. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Insert an opening pick: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Insert an opening pick: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
    • Pry up on the pick to release the clips securing the back cover to the frame.
    • You will hear several clicks while prying up.
  3. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Remove the back cover: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Remove the back cover: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Remove the back cover: adım 3, 3 resimden 3.
    • Lift the back cover up and remove it from the chassis.
    • You will hear several clicks while lifting up.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  4. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement, Display: adım 4, 1 resimden 1.
    • Remove the six 2mm screws from the display hinges using a Phillips #0 screwdriver.
    • Remove each of the cables connecting the display assembly to the motherboard:
    • A display cable on the left
    • Two coaxial cables in the middle
    • Two more cables on the right
  5. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad X1 Carbon 7th Gen Display Replacement: adım 5, 2 resimden 2.
    • Lift the computer up and rotate the display backwards until it is detached from the rest of the computer as shown.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
great guide! BUT the "index page" for the thinkpad x1 carbon 7th gen (Lenovo ThinkPad X1 Carbon 7th Gen) doesn't list it, so something is kind of broken...
K. Krass - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 90
Her zaman: 3,391
