Giriş
This guide will teach you how to remove the trackpad, the component used to move the cursor, for the Lenovo Thinkpad X1 Carbon 7th Gen computer.
Often when a computer is getting older the trackpad will start to deteriorate , see our trouble shooting page, making basic computer functions much more difficult. This guide will teach you how to uninstall and reinstall a new trackpad into your computer.
Make sure your computer is unplugged and powered off before attempting any repairs.
Neye ihtiyacın var
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
Peel back the black adhesive tape covering the ribbon cable connecting the trackpad and fingerprint scanner to the motherboard.
Remove the four 2mm screws securing the trackpad with a Phillips #000 screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
