Ana içeriğe geç
Lenovo ThinkPad X1 Extreme RAM Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Extreme RAM Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme RAM Replacement, RAM: adım 2, 1 resimden 1.
    • Use an opening tool to unlatch the silver gate on the side of the RAM by pushing it away from the component.
    • Repeat the same process to the other side of the RAM.
  3. Lenovo ThinkPad X1 Extreme RAM Replacement: adım 3, 1 resimden 1.
    • Gently grab the RAM and slide it up and away from the connector at the bottom of the component.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,025
