Ana içeriğe geç
Lenovo ThinkPad X1 Extreme Speakers Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme Speakers Replacement, Speakers: adım 2, 1 resimden 1.
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Extreme Speakers Replacement: adım 3, 1 resimden 1.
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
Sonuç
Kristen Gismondi
82.719 İtibar
202 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 357
