Ana içeriğe geç
Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Speakers: adım 2, 1 resimden 1.
    • Use a Phillips #00 head screwdriver to remove the four 4 mm screws above the battery.
  3. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: adım 3, 1 resimden 1.
    • Lift the speaker modules on either side of the battery out of its pegs, and unwind the cable from the front of the battery.
    • Set the speaker modules out of the way.
  4. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Use tweezers to peel the plastic cover off the connector.
    • Use a spudger or your fingernail to pry up the battery straight up from the motherboard.
    This does not mention the wire that connects the speakers entwined with the battery nor the screws that hold the battery down. This is not a huge deal, just pointing it out
    José B. - Yanıt
  5. Lenovo ThinkPad X1 Gen 1 Extreme Battery Replacement: adım 5, 1 resimden 1.
    • Lift the battery out of the frame and remove it from the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Beckham Richmond
466 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G3, Regan Winter 2020 Cal Poly, Team S7-G3, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G3
4 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
Could I use the same battery for my X1 Extreme Gen 1 laptop? Thanks.
Huy Tran - Yanıt
Thank you so much for this illustration on how to take off the battery. I was like already stuck at just the screws not coming off. This helped immensely.
Rafael Dolfe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 45
Son 30 gün: 206
Her zaman: 11,445
