Ana içeriğe geç
Lenovo ThinkPad X1 Yoga (6th Gen) Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Base Panel: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement, Fan: adım 2, 2 resimden 2.
    • Use a Phillips #000 screwdriver to loosen the four 5 mm captive screws.
    • The captive screws will stay attached to the fan as you remove it.
  3. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen)  Fan Replacement: adım 3, 3 resimden 3.
    • Place the pointed tip of a spudger behind the small plastic tab on either side, and "walk" the fan's connector out of its port, alternating between tabs, until the plug disconnects.
    • Lift the fan up and out.
Sonuç
3 Yorum
Hi, Do you know what is the fan part number? Where did you get the fan from?
hamedabedi - Yanıt
Responding to this oooold comment: Part# 5H40W36671 5H40W36671 - Lenovo Laptop CPU Fan & Heatsink - Genuine
You can look up, and sometimes order, Lenovo parts at their website. They even sometimes have instructions and videos for parts. Many models also have service guides available, at least the Thinkpads do (maybe because they are intended as "corporate" machines).
https://support.lenovo.com/us/en/parts-l...
Alan Johnson - Yanıt
Also note: when replacing, you need to clean off and replace the thermal compound on the chip dies. And technically the screws should be tightened down in the order shown by the numbers next to each screw...that is to try to ensure the thermal paste is spread evenly/correctly across the chip die when tightening.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 47
Her zaman: 1,166
