Ana içeriğe geç
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: adım 3, 1 resimden 1.
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 50
Her zaman: 1,643
