Ana içeriğe geç
Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Base Panel: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: adım 2, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: adım 2, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Battery: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the five 4.5 mm screws securing the battery.
    • Lift the battery up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: adım 3, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: adım 3, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement, Speaker: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 1.8 mm screws.
  4. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 4, 3 resimden 3.
    • Use the spudger to lift the flap covering the speaker wire.
    • Starting at the top of the right speaker, follow the wire connected to the top of the left speaker. Use the tip of a spudger to free the wire from the plastic brackets it lies under.
    • Starting from near the bottom-left side of the right speaker, follow the lower wire, unseating the speaker cable as you go.
  5. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 5, 3 resimden 1. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 5, 3 resimden 2. Lenovo ThinkPad X1 Yoga (6th Gen) Speaker Replacement: adım 5, 3 resimden 3.
    • Place your fingernails behind each of the plastic tabs on the speaker's plug and pull directly backwards until the plug releases from its port.
    • Lift the speakers up and out.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 33
Her zaman: 557
