Ana içeriğe geç
Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 3, 1 resimden 1.
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: adım 4, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Fan Replacement: adım 6, 2 resimden 2.
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
Sonuç
Alex Shacoski
270 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G3
5 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
When you remove a heasink (or heat transfer pipe) from a chip, shouldn't you re-apply any thermal paste? Surely it had some?
Edward Dekkers - Yanıt
after pressing power button Cooling fan runs for 2 sec then it stays off . What is the problem ?
Tonmoy Arafin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 910
