Ana içeriğe geç
Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 3, 1 resimden 1.
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement, Pen Charging Port: adım 4, 1 resimden 1.
    • Remove the pen from its slot on the side of the laptop before removing the pen charging port.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 5, 2 resimden 2.
    • Lift the tab with a spudger to expose the ribbon cable.
    • Do not use the metal spudger unless if it's for serious prying power. The metal spudger may damage or puncture the internal components in your device, so please use a plastic opening tool or nylon spudger instead.
    • Carefully pull out the ribbon cable using Pro/ESD/Angled tweezers.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 6, 2 resimden 2.
    • Disconnect the red and black charger wire from the port on the circuit board.
    • Remove two 4 mm screws using the Phillips #0 screwdriver.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the circuit board by hand.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Pen Charging Port Replacement: adım 8, 2 resimden 2.
    • Remove a single 6 mm screw from the charging port using the Phillips #0 screwdriver.
    • Remove the black charging port using your fingers.
Sonuç
Katrina Lee
154 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 2,117
