Ana içeriğe geç
Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Speakers: adım 4, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Speakers: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 6, 2 resimden 2.
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Battery: adım 7, 1 resimden 1.
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 9, 1 resimden 1.
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Wi-Fi Card: adım 10, 3 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Wi-Fi Card: adım 10, 3 resimden 2. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement, Wi-Fi Card: adım 10, 3 resimden 3.
    • Disconnect the gray and black coaxial cables from the Wi-Fi-Card using a spudger.
    • Be gentle as you're disconnecting these cables. The base can break off the Wi-Fi card if the they're pulled on too hard.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 11, 1 resimden 1.
    • Remove the 3 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad X1 Yoga 2nd Generation Wi-Fi Card Replacement: adım 12, 2 resimden 2.
    • Gently slide the Wi-fi card out from the slot.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 610
