Ana içeriğe geç
Lenovo ThinkPad X1 Yoga Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: adım 1, 3 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: adım 1, 3 resimden 2. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Back Cover: adım 1, 3 resimden 3.
    • Be sure to power off and unplug your device before you begin your repair.
    • Flip the computer over so the bottom is facing up.
    • Remove nine 4mm Phillips #1 screws from the bottom of the computer.
    • Use an iFixit opening tool to pry the back cover off of the laptop.
  2. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Speakers: adım 2, 1 resimden 1.
    • Remove the five 4.5mm Phillips #1 screws that secure the battery.
  3. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, push the sides of the white speaker wire toward the battery (where it says Lenovo) to unplug it.
  4. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 4, 3 resimden 3.
    • Remove the speakers from either side of the battery. The connecting wire will unthread from the sides of the battery.
  5. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: adım 5, 3 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: adım 5, 3 resimden 2. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Battery: adım 5, 3 resimden 3.
    • Lift the plastic black strip cover that's laying over the battery connector.
    • Use the iFixit opening tool to flip up and disconnect the black battery connector from its motherboard socket.
    • Gently pull the connector away from the battery to pull it out of the slot.
  6. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 6, 1 resimden 1.
    • Lift and remove the battery away from the computer.
  7. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Trackpad: adım 7, 2 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement, Trackpad: adım 7, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove four 4.5 mm screws from the trackpad.
  8. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 8, 2 resimden 2.
    • Using the iFixit opening tool, flip up the small covers to the track pad cable connectors.
    • Gently pull the cable out of place.
  9. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 9, 2 resimden 1. Lenovo ThinkPad X1 Yoga Trackpad Replacement: adım 9, 2 resimden 2.
    • Using iFixit opening tools, lift up the frame of the track pad.
    • Gently remove the track pad away from the computer.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 54
Her zaman: 2,726
