Ana içeriğe geç
Lenovo ThinkPad X100e Fan Replacement
Neye ihtiyacın var
    1. Lenovo ThinkPad X100e Fan Replacement, Fan: adım 1, 1 resimden 1.
      • Flip the computer over and remove the battery.
      • Please view the Battery Replacement Guide if more detailed instructions are needed.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo ThinkPad X100e Fan Replacement: adım 2, 1 resimden 1.
      • Locate the screws on the back of the laptop. Unscrew all 7 screws using a magnetic screwdriver fit with a PH0 bit.
      • All 7 screws should be bounded to the panel.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo ThinkPad X100e Fan Replacement: adım 3, 1 resimden 1.
      • Remove the following screws with a magnetic screwdriver fit with a PH0 bit.
      • There should be 2 screws total.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo ThinkPad X100e Fan Replacement: adım 4, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    5. Lenovo ThinkPad X100e Fan Replacement: adım 5, 1 resimden 1.
      • Using the magnetic screwdriver fit with a PH0 bit, unscrew the two screws shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    6. Lenovo ThinkPad X100e Fan Replacement: adım 6, 1 resimden 1.
      • Disconnect the two wired ribbons by pulling up the little black tabs, then pull the wires out.
      FixBot'a Sor
      Yorum Ekle
    7. Lenovo ThinkPad X100e Fan Replacement: adım 7, 1 resimden 1.
      • Disconnect the little black wire by simply pulling it out.
      FixBot'a Sor
      Yorum Ekle
    8. Lenovo ThinkPad X100e Fan Replacement: adım 8, 1 resimden 1.
      • Using the spudger, go beneath the frame to pry the frame off the device.
      • The best place to start from is the bottom, near the trackpad.
      • Place the frame aside once this step is completed.
      FixBot'a Sor
      Yorum Ekle
    9. Lenovo ThinkPad X100e Fan Replacement: adım 9, 1 resimden 1.
      • Using the magnetic screwdriver, unscrew all 8 screws shown.
      • Be sure to place all your screws on the magnetic mat.
      FixBot'a Sor
      Yorum Ekle
    10. Lenovo ThinkPad X100e Fan Replacement: adım 10, 1 resimden 1.
      • Disconnect the three wired ribbons on the top left side of the panel.
      FixBot'a Sor
      Yorum Ekle
    11. Lenovo ThinkPad X100e Fan Replacement: adım 11, 2 resimden 1. Lenovo ThinkPad X100e Fan Replacement: adım 11, 2 resimden 2.
      • Disconnect the wired plug, then close the device and flip it over.
      FixBot'a Sor
      Yorum Ekle
    12. Lenovo ThinkPad X100e Fan Replacement: adım 12, 2 resimden 1. Lenovo ThinkPad X100e Fan Replacement: adım 12, 2 resimden 2.
      • Simply pull the two plugs up and out to disconnect the wires.
      FixBot'a Sor
      Yorum Ekle
    13. Lenovo ThinkPad X100e Fan Replacement: adım 13, 1 resimden 1.
      • Flip the device back over to untape the two black wires located at the bottom left corner of the device.
      FixBot'a Sor
      Yorum Ekle
    14. Lenovo ThinkPad X100e Fan Replacement: adım 14, 2 resimden 1. Lenovo ThinkPad X100e Fan Replacement: adım 14, 2 resimden 2.
      • Simply disconnect the blue connector at the center of the device.
      FixBot'a Sor
      Yorum Ekle
    15. Lenovo ThinkPad X100e Fan Replacement: adım 15, 1 resimden 1.
      • Using your fingers, slowly push the panel out of the plastic body.
      • Place the plastic body aside once the panel is free.
      FixBot'a Sor
      Yorum Ekle
    16. Lenovo ThinkPad X100e Fan Replacement: adım 16, 2 resimden 1. Lenovo ThinkPad X100e Fan Replacement: adım 16, 2 resimden 2.
      • Using the same magnetic screwdriver, unscrew the two screws as shown in the picture.
      FixBot'a Sor
      Yorum Ekle
    17. Lenovo ThinkPad X100e Fan Replacement: adım 17, 2 resimden 1. Lenovo ThinkPad X100e Fan Replacement: adım 17, 2 resimden 2.
      • Disconnect the plug right below the Fan. A pair of pliers might be useful during this step.
      • If you need to clean your cooling fan, simply spray compressed air onto the fan to clean in and rid it of debris. Repeat the previous steps in reverse order to put your laptop back together.
      • If you need to replace your cooling fan, simply place your new fan in, and follow the steps in reverse order to put your device back together.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Then you are good to go.
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,660
