Ana içeriğe geç
Lenovo ThinkPad X100e Screen Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X100e Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo ThinkPad X100e Screen Replacement, Screen: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
  2. Lenovo ThinkPad X100e Screen Replacement: adım 2, 1 resimden 1.
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
  3. Lenovo ThinkPad X100e Screen Replacement: adım 3, 1 resimden 1.
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
  4. Lenovo ThinkPad X100e Screen Replacement: adım 4, 1 resimden 1.
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
  5. Lenovo ThinkPad X100e Screen Replacement: adım 5, 1 resimden 1.
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
  6. Lenovo ThinkPad X100e Screen Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X100e Screen Replacement: adım 6, 2 resimden 2.
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
  7. Lenovo ThinkPad X100e Screen Replacement: adım 7, 1 resimden 1.
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
  8. Lenovo ThinkPad X100e Screen Replacement: adım 8, 2 resimden 1. Lenovo ThinkPad X100e Screen Replacement: adım 8, 2 resimden 2.
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
  9. Lenovo ThinkPad X100e Screen Replacement: adım 9, 1 resimden 1.
    • Remove the connector carefully with the spudger tool.
  10. Lenovo ThinkPad X100e Screen Replacement: adım 10, 1 resimden 1.
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Orly Guerra
448 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 914
