Ana içeriğe geç
Lenovo ThinkPad X140e Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X140e Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop and unplug the charging cable.
    • Failure to remove the charging cable may cause electric shock.
    • Flip the laptop upside down.
    • Rotate the laptop so that the battery is facing away from you.
  2. Lenovo ThinkPad X140e Battery Replacement: adım 2, 1 resimden 1.
    • Push the first switch on the left to the right until you hear a click. This means the battery is unlocked and can be removed.
  3. Lenovo ThinkPad X140e Battery Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X140e Battery Replacement: adım 3, 2 resimden 2.
    • Push the second switch on the right to the right, hold it there with your right hand and continue to the next step.
    • While holding the right switch open, take your free hand and pull the battery out.
Sonuç
Dylan Halland
324 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G5
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
I did this, but the computer says that the battery is not genuine, and then refuses to charge the battery. What do I do?
Justine Akehurst - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,070
