Ana içeriğe geç
Lenovo ThinkPad X140e Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X140e Hard Drive Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the laptop upside down so that the battery is facing away from you.
    • Battery removal is not necessary to complete this guide.
  2. Lenovo ThinkPad X140e Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X140e Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the three 3 mm Phillips #0 screws on the back panel.
    • Remove each screw using a small Phillips #0 screwdriver.
  3. Lenovo ThinkPad X140e Hard Drive Replacement: adım 3, 1 resimden 1.
    • Using a small plastic opening tool, pry off the back casing starting at a point closest to you and working around the perimeter of the case.
  4. Lenovo ThinkPad X140e Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • After removing the back panel, locate the hard drive located to the far left. It is distinguishable from other parts based on it's rectangular shape.
  5. Lenovo ThinkPad X140e Hard Drive Replacement: adım 5, 2 resimden 1. Lenovo ThinkPad X140e Hard Drive Replacement: adım 5, 2 resimden 2.
    • Remove the four 3.5 mm Phillips #0 screws attached on the four corners of the hard drive.
  6. Lenovo ThinkPad X140e Hard Drive Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X140e Hard Drive Replacement: adım 6, 2 resimden 2.
    • Slide the hard drive to the left.
    • Grip the hard drive on both sides and proceed to lift up to remove the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
kevin hull
213 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G5
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
How do you reformat the hard-drive? I understand physically replacing the equipment, but how do I reformat it with a windows operating system? My email is amwindham@aol.com.
amwindham - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,663
