Ana içeriğe geç
Lenovo ThinkPad X140e Keyboard Replacement
Neye ihtiyacın var
    1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Set the laptop facing you with the screen open.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo ThinkPad X140e Keyboard Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X140e Keyboard Replacement: adım 2, 2 resimden 2.
      • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo ThinkPad X140e Keyboard Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad X140e Keyboard Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad X140e Keyboard Replacement: adım 3, 3 resimden 3.
      • Flip up the ZIF connector that is holding the small ribbon cable in place.
      • Proceed to pull out the small ribbon cable
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo ThinkPad X140e Keyboard Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X140e Keyboard Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X140e Keyboard Replacement: adım 4, 3 resimden 3.
      • Flip up the ZIF connector that is holding the larger ribbon cable in place.
      • Proceed to pull out the large ribbon cable.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
kevin hull
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G5
4 Üyeler
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - Yanıt Paylaş
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - Yanıt Paylaş
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - Yanıt Paylaş
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 48
Her zaman: 2,303
