Ana içeriğe geç
Lenovo ThinkPad X140e Speakers Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X140e Speakers Replacement, Keyboard: adım 1, 1 resimden 1.
    • Set the laptop facing you with the screen open.
  2. Lenovo ThinkPad X140e Speakers Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 2, 2 resimden 2.
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
  3. Lenovo ThinkPad X140e Speakers Replacement: adım 3, 3 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 3, 3 resimden 2. Lenovo ThinkPad X140e Speakers Replacement: adım 3, 3 resimden 3.
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
  4. Lenovo ThinkPad X140e Speakers Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X140e Speakers Replacement: adım 4, 3 resimden 3.
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
  5. Lenovo ThinkPad X140e Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • Flip the laptop upside down such that the battery would be facing away from you.
    • Remove the two 3mm Phillips #0 screws in the back located on either side of the battery.
    • Back panel and battery removal are not necessary for completion of this guide.
  6. Lenovo ThinkPad X140e Speakers Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 6, 2 resimden 2.
    • Flip the laptop right-side up and open it so that the screen is facing you.
    • Pry off the front panel using a small plastic opening tool starting at a corner and working around the perimeter
  7. Lenovo ThinkPad X140e Speakers Replacement: adım 7, 2 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 7, 2 resimden 2.
    • The speakers are located on the bottom of the laptop, where the mouse pad is located.
    • Remove the four 4.5 mm Phillips #0 screws on either side of both speakers.
  8. Lenovo ThinkPad X140e Speakers Replacement: adım 8, 3 resimden 1. Lenovo ThinkPad X140e Speakers Replacement: adım 8, 3 resimden 2. Lenovo ThinkPad X140e Speakers Replacement: adım 8, 3 resimden 3.
    • Remove the cable that is attached from the speakers to the board.
    • Unhook the black wire that connects the speaker on the left to the speaker on the right.
    • After unhooking the wire, simply pull the speakers out of the laptop.
Sonuç
Dylan Halland
318 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 6
Son 30 gün: 31
Her zaman: 2,877
