Ana içeriğe geç
Lenovo ThinkPad X250 RAM/SSD Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X250 RAM/SSD Replacement, Removing the back cover: adım 1, 3 resimden 1. Lenovo ThinkPad X250 RAM/SSD Replacement, Removing the back cover: adım 1, 3 resimden 2. Lenovo ThinkPad X250 RAM/SSD Replacement, Removing the back cover: adım 1, 3 resimden 3.
    • Unscrew the 8 screws holding the back panel in place.
    • Use a plastic prying tool to release all the clips holding the panel in place.
  2. Lenovo ThinkPad X250 RAM/SSD Replacement, RAM Replacement: adım 2, 1 resimden 1.
    • In the RAM slot, you will see 2 metal clips on either side. Pull on both and the ram will pop up.
    • Take out the stick of RAM.
    • Insert your new stick of RAM and push downwards.
  3. Lenovo ThinkPad X250 RAM/SSD Replacement, HDD/SSD Replacement: adım 3, 1 resimden 1.
    • Unscrew the SSD/HDD placer
    • Then, remove and pull the SSD/HDD out.
    • Put in your new SSD.
    • Re-Plug the SATA Connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Princemiguelcayetano
371 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 30
Son 30 gün: 101
Her zaman: 298
