Ana içeriğe geç
Lenovo ThinkPad X250 Thermal Paste Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: adım 1, 3 resimden 1. Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: adım 1, 3 resimden 2. Lenovo ThinkPad X250 Thermal Paste Replacement, Opening the back panel: adım 1, 3 resimden 3.
    • Unscrew the 8 screws holding the back panel in place.
    • Use a plastic prying tool to release all the clips holding the panel in place.
    • Remove the first battery by sliding the notches and pulling the battery outwards.
  2. Lenovo ThinkPad X250 Thermal Paste Replacement, Disconnect the internal battery: adım 2, 1 resimden 1.
    • It is recommended to disconnect the second battery.
    • Disconnect the wire from the motherboard.
  3. Lenovo ThinkPad X250 Thermal Paste Replacement, Removing the CPU cooler: adım 3, 2 resimden 1. Lenovo ThinkPad X250 Thermal Paste Replacement, Removing the CPU cooler: adım 3, 2 resimden 2.
    • Unscrew the 4 screws holding the CPU cooler. Disconnect the fan cable by releasing the latch on the connector and pulling the cable out.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton buds or paper towel, be careful not to go too hard on the CPU.
  4. Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: adım 4, 3 resimden 1. Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: adım 4, 3 resimden 2. Lenovo ThinkPad X250 Thermal Paste Replacement, Apply new thermal paste: adım 4, 3 resimden 3.
    • Once you have removed the old thermal paste, it's time to apply the new paste. This model has a hole in the heatsink so it does not need thermal paste applied on the smaller pad.
    • Do not use too much thermal paste, just enough to cover the bigger portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Put the heatsink back carefully and tighten the screws in order 1, 3, 2, 4 to ensure even pressure. Don't forget to plug in the fan cable again.
  5. Lenovo ThinkPad X250 Thermal Paste Replacement, Clean your laptop: adım 5, 1 resimden 1.
    • It is recommended to use compressed air to remove any dust in the laptop and the fan.
    • Don't forget to plug in the second battery before closing the back panel!
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Simeon Brankov
7.279 İtibar
54 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 29
Son 30 gün: 102
Her zaman: 4,874
