Ana içeriğe geç
Lenovo ThinkPad X260 Internal Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: adım 1, 2 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: adım 1, 2 resimden 2.
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: adım 2, 3 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement: adım 2, 3 resimden 2. Lenovo ThinkPad X260 Internal Battery Replacement: adım 2, 3 resimden 3.
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: adım 3, 3 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: adım 3, 3 resimden 2. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: adım 3, 3 resimden 3.
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: adım 4, 3 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement: adım 4, 3 resimden 2. Lenovo ThinkPad X260 Internal Battery Replacement: adım 4, 3 resimden 3.
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: adım 6, 1 resimden 1.
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: adım 7, 3 resimden 1. Lenovo ThinkPad X260 Internal Battery Replacement: adım 7, 3 resimden 2. Lenovo ThinkPad X260 Internal Battery Replacement: adım 7, 3 resimden 3.
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
Sonuç
Ammarin Sinthana
97 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Summer 2023 IUPUI, Team 1-3, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S1G3
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 36
Son 30 gün: 138
Her zaman: 1,439
