Ana içeriğe geç
Lenovo ThinkPad X280 Battery Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X280 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Battery Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X280 Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Battery Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X280 Battery Replacement: adım 3, 2 resimden 2.
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Battery Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X280 Battery Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X280 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Haley Curry
491 İtibar
2 adet Kılavuz yazıldı
2 Yorum
but what about the batteries connection to the mobo?
edit: nvm, i assumed it was a cable not just a connector
Matthew Gould - Yanıt
I'll chime in with Matthew Gould:
The last step, "Remove the battery", could stand expansion. It took me some time to figure out that the edge of the battery with the connector simply lifts up rather than sliding out toward the user (fixer? repairer?). One more picture showing that action would help.
The rest of the process, including purchasing the battery from ifixit, was like butter.
Having said that, I am so thankful for ifixit!
Andrew Rinehart - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 39
Son 30 gün: 158
Her zaman: 9,032
