Ana içeriğe geç
Lenovo ThinkPad X280 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X280 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Speaker Replacement: adım 2, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Speaker Replacement: adım 3, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 3, 2 resimden 2.
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 1. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 2. Lenovo ThinkPad X280 Speaker Replacement, Battery: adım 4, 3 resimden 3.
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 1. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 2. Lenovo ThinkPad X280 Speaker Replacement, Speakers: adım 5, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each speaker.
    • Once done, the speakers should still be attached with a red wire connecting to each other.
  6. Lenovo ThinkPad X280 Speaker Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X280 Speaker Replacement: adım 6, 2 resimden 2.
    • Using the black spudger, push the white plastic connector out of the the tan plug.
  7. Lenovo ThinkPad X280 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove speakers and wiring from device.
Sonuç
Jordan Wooten
615 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 1,788
