Ana içeriğe geç
Lenovo ThinkPad X390 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo ThinkPad X390 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Power down and unplug the laptop before proceeding.
    • Use a Phillips #0 screwdriver to remove the five screws on the base cover.
  2. Lenovo ThinkPad X390 Motherboard Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool between the base cover and the chassis.
    • Slide the tool along the perimeter of the case and push down as you go to release the base cover.
    • Lift the base cover up and off.
  3. Lenovo ThinkPad X390 Motherboard Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
  4. Lenovo ThinkPad X390 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
  5. Lenovo ThinkPad X390 Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift the battery up and out of its housing.
  6. Lenovo ThinkPad X390 Motherboard Replacement: adım 6, 2 resimden 1. Lenovo ThinkPad X390 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the four 5.2 mm screws from the fan using the Phillips #0 screwdriver.
    • Use tweezers to carefully unplug the fan ribbon cable.
  7. Lenovo ThinkPad X390 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the eleven 5.2 mm screws from the motherboard using a Phillips #0 screwdriver.
  8. Lenovo ThinkPad X390 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use tweezers to carefully unplug the four motherboard ribbon cables.
  9. Lenovo ThinkPad X390 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use tweezers to carefully unplug the black and red harness cables.
  10. Lenovo ThinkPad X390 Motherboard Replacement: adım 10, 1 resimden 1.
    • Carefully lift the motherboard up and out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 2,326
